aluminum spool gun and bobcat 250EFI?
  • aluminum spool gun and bobcat 250EFI?
    have a 2012 bobcat 250 EFI and need to put a MIG aluminum spool gun into the equation for a project upcoming in the field. What do I need to make this setup work? I was told I needed to get a new Trailblazer instead from my local welding shop. Any way I can use an adapter to make work? Thanks!
    Sure you need a WC-115 (with contactor) and a spoolmatic 30A
      can someone please confirm that I would need the following items then?
      quantity 1. WC-115A with contactor (part #137-546-01-1)
      quantity 1. Spoolmatic 30A (part #130831)
      anything else?
      Thanks!
        Those would be the correct items. You will need a chunk of weld cable to go from the Bobcat to the WC-115, for a work cable you can use your work cable that goes with your stick cables and of course you will need argon gas, aluminum welding wire and I would suggest some extra contact tips as well.
          Kevin -- thank you.
            Miller Kevin, is there any difference in the preformance of
            the two machines Bobcat vs Trailblazer, I have welded
            extensively with the Trailblazer and a 30A spoolgun, but not with
            the Bobcat..Trailblzer runs great even with a Promax gun....just wondering....Paul
