Can I run a LN-9 on my XMT 304 CC/CV?
  • Can I run a LN-9 on my XMT 304 CC/CV?
    I have an XMT 304 cc/cv. My 22A feeder was barrowed and won't return. I have an old Lincoln LN-9 of dads that only has 500 lbs. of dual shield through it. The R3R we used to run it on was sold so I want to know if I can put a 9 pin on my cord to run the LN-9 with my XMT 304 and Optima Pulse GMAW control. The LN-9 is 110 volt and the 22A was 28v I guess. The Gas valve is still on the LN-9 and it is110 Volt. I saw an add for Cords to hook Lincolns to Millers But lost track of it so I don't know if it will fit my application.
    Thanks!!!!!!!!!!!!!!!!!!!!!!!!!
      Sure: Pretty easy really.
      lincoln Miller
      9 pin 14 pin
      D I
      C G
      I K
      A A (you have a couple of choices here but this is easiest)
      B B (same as above)
      G E (The next 3 are your voltage control, you may have to change pots to a 1K)
      F C
      H D
      E would be a separate wire to your work piece
        Thanks you 're a pro.
        You saved me to years ago you're one of the few who can walk the walk and back up your Talk. Thanks I appreciate it.
