Aerowave Over voltage shutdown
  • Aerowave Over voltage shutdown
    Hi Guys, I'm having problems with my Aerowave. It shuts down randomly with the over voltage shutdown. Only on AC. It seems to happen more often if the frequency is set much higher than 60. I took the machine to the service center. They did a test and found nothing wrong. Said it could be my input power. I checked all the connections, had an electrician come out and check voltage etc. Nothing out of the ordinary. I read the trouble shooting section of the manual. It says move cables away from the machine. Any ideas? Thanks for your help.
    Sounds more like a corroded or loose connector on the back of the output studs, best to remove the panels, remove and dielectric grease all the molex board connectors.
    Pull and reseat the ribbon cables(no dielectric grease for the ribbons cables)
    Tighten up all other connectors.
    Problem should vanish.
      Thanks, I'll give that a try.
        Did this resolve your issue?
