Millermatic 200 gun cable flex groumet
  • Millermatic 200 gun cable flex groumet
    Just picked up a Millermatic 200. Where the gun cable plugs into the unit there is a (for lack of the actual name) flexible groumet that shrouds the gun cable. Due to age of the unit this groumet has cracked and seperated to where one can actually see the woven wire that wraps the cable. I've been advised to just tape it real good with electric tape and its good to go. Now for the reason for this post - Is it safe to tape it up or should I replace groumet (whatever its called) or the dreaded replace the entire gun cable. The welder works fine. Serial number - JK634850 and I believe the gun to be GA - 20C. thanx
    I assume you're referring to what is called the "strain relief" in the G-20C manual http://www.millerwelds.com/om/o1025d_mil.pdf as item #33. If so and you want to replace it rather than tape it up you can get one here http://miller4less.com/advanced_sear...d5ecaf5cda9872 for $11.35.
    However, I suggest buying two as they have a minimum order amount of $20 so you'd wind up paying about the same for one as you would for two anyhow and you could replace both ends. Or figure out if there is any other part(s) you may need/want to add up to at least the minimum order amount.
    If you don't have it, you can download the MM200 manual here:
    http://www.millerwelds.com/om/o1303m_mil.pdf
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
      Many thanx for great info
      You nailed it. Will order 2. I was somewhat skeptical about taping.
        I have same problem
        Duane55,
        Will all the information be accurate for my machine as well? S/N JF918470
        I did s/n search and nothing came up. Machine must be to old!
          I'm no Duane(by a long shot) but here are your manuals,
          http://www.millerwelds.com/om/o1303p_mil.pdf
            I have run those GA-20c gun for a while and finally replaced with a Bernard Q gun and Miller M-25, both are better guns than than the GA-20c. They are both available on ebay for about $100.
              M-25 is a fair gun.....CenterFire ROCKS!
                I always prefer to replace parts that go out rather than finding a "fix". Fixes are fine if they're safe and I just need to get the job done. But I think the resale value is better down the road with new OEM parts.
                Lincoln Vantage 400
                Trailblazer® 302 Air Pak™
                Miller Dynasty® 350
                Millermatic 350P Aluminum
                Millermatic® 252
                Syncrowave 351
                Lincoln LN-25 Pro
                Multimatic™ 200
                XR-Aluma Pro Gun
                Diversion™ 180
                Spectrum® 625 X-TREME™
                Victor Oxy/Acetylene Set
                  Both the Bernard Q and teh M-25 are OEM guns.
                    The GA-20C was replaced with the M-25 as the OEM gun in 1995.
