Help: A Question of cutting torches & math . . . :-)
  • Help: A Question of cutting torches & math . . . :-)
    Hi Folks,
    Just learning and I'm looking for a formula, if there is one for getting a ballpark figure of how much O2 and how much gas to bring to a jobsite for cutting.
    Is there a formula that includes the following factors:
    Thickness of material
    Length of cut
    O2 in cf
    Acetylene in cf
    and assuming the correct tip size (Jeffus, 6th ed. pg 159)
    and median gas flow for that tip size:
    for example: 1" thick material, #2 Smith or Victor tip, O2=35-40(37.5) psi and Fuel@3-5psi (4) what would be the number of inches/feet/meters that could be cut with how many cf of each gas (O2 & fuel) ?
    What I'm really asking is to find a straight forward method of pricing a demo.
    Gas & O2 costs are one factor but the other is knowing how much and what size bottles as well as the amount of hose to haul to the site. My time is the easy part.
    Ed Conley
    Passport Plus w/Spool Gun
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
      THANKS! for the tipchart...
      Originally posted by Broccoli1 View Post
      BTW there is a problem with
      1...they're using a cut-rate redirection service: may not work in your browser, you need
      2...the link on their homepage for their tip chart doesn't work. this one does:
