Heavy Haul Trailer
  • Heavy Haul Trailer
    One of my customers called this mourning,their heavy haul truck took out part of a rail road crossing! Truck loaded with a cat345 trackhoe,boom laid down in between the main center beams of the trailer,well when he caught the track doing 30 mph it stopped the truck almost in its tracks.Well the backhoe slid forward on the trailer ended up on top of 5th wheel,never slid off,but the boom took out 5 crossmembers between the main beams.Need to replace the bent crossmembers,This is probably t-100 steel the main beams
    I'm thinking cut out old ones ,preheat main beams and weld back new rectangle tubing 6x12x 1/4 wall back in with 7018. Anybody out there have any experience with these heavy haul trailers?
    /22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
    33x33 enclosed shop when its to cold or windy outside
    miller 210
    miller 875 plasma
    victor oxy/accet
    unihydro 45ton ironworker
    miller 180 tig
    ole lincoln ac/dc buzzbox
    milwaukee power tools
    and everything in between
    2007 trailblazer 302
    Bailiegh 210 miter saw-2008
    Beer Fridge
    6000# cat forklift
    36" port-a-cool fan
    Dake G-75 Belt grinder
    3035 Spoolgun
    I can't tell you how to fix it but I'd like to see a pic or two of the situation.
    Jim
      Pictures would be great...........
      Railmen
      2007 Trailblazer 302G
      2004 Invision 354MP
      1999 60 series feeder
      2005 Maxstar 200DX
      2007 CST280
      1999 HF 251-1
      older Hobart hefty wire feeder
      Hyperthrem 600
      Maxstar 150S(such a cute welder)
      had and sold........
      2003 XMT 304CC/CV
      1947 Lincoln SA200G short hood
      1963 Lincoln SA200G
      1975 Lincoln SA200G(best machine ever had )
      1970's Lincoln SAE400G
      2 Maxstar's 200DX's
      1 Maxstar 200SD
      CST 280
      2 CST 250
      MM130
      Railmen
        Actually i missed all the fun,they had the trailer at their shop this mourning. One of the mechanics said everybody (law&railroad people)was on the scene .Good part no other vehicles were involved, the driver was shook up a bit from the sudden stop ,couple cuts on the head from the steering wheel and fortunately it was around 7:00 a.m. in the mourning hardly no traffic on sunday mourning.
        miller 210
        miller 875 plasma
        victor oxy/accet
        miller 180 tig
        Beer Fridge
        6000# cat forklift
        36" port-a-cool fan
        3035 Spoolgun
          I checked my charts, unless I over looked it, I cannot find T-100! Is this some type of T-1 that Im not familiar with?
          Caution!
          These are "my" views based only on my experiences in my little bitty world.
            I meant some type of high tensile steel ,sorry about that. Ilooked on the loadking trailer website states 100,000/80,000 ksi steel
            miller 210
            miller 875 plasma
            victor oxy/accet
            miller 180 tig
            Beer Fridge
            6000# cat forklift
            36" port-a-cool fan
            3035 Spoolgun
              There are a couple of guys over on the shopfloortalk.com board who repair this kind of stuff regularly, and seem to do a real good job of it, you might post over there too.
                Most likely T-1.
                I worked on some heavy haul lowboys that were made with T-1. These trailers were grossly over loaded, and abused! Cracked welds from one end to the other. We arced the bad welds out, and re-welded with 110-18. Everything went according to plan, until the post weld cool down!
                Caution!
                  Hey sonora are you refering to the steel cracking along the outside of the new welds?
                  miller 210
                  miller 875 plasma
                  victor oxy/accet
                  miller 180 tig
                  Beer Fridge
                  6000# cat forklift
                  36" port-a-cool fan
                  3035 Spoolgun
                    Yes!_______
                    Caution!
                      T-1, T-100, QT (Quenched and Tempered) 100 ... Same - Same just different terminology depending on what your local steel shop calls it.
                      Main rails should be QT-100.
                      Cross members will be "Mild" Steel, and should be "Wide Flange" available at just about any steel supplier.
                      I pre-heat rails, then weld out with Hobart Fabco110 (Dual Shield Flux Core) or with 110-18 to match the characteristics of the stronger of the 2 metals, which is the QT-100.
                      Other than the way the damage was caused, it is a pretty common, and straight forward repair.
                      Have a Good Night.
                      Later,
                      Jason
                      Professional Spark Generator by Trade.
                        Hello shade. Do you have any picture? I think your trailers were grossly over loaded, and abused. Trailers are known to have the capacity to easily carry a heavy or any other vehicle.
                        Read information available about Heavy Hauling!
                          I agree with Black Wolf, You want to use the stronger rod.
                            Old thread brought back to life by the two previous Spammer post
                            Links in their posts
                            Ed Conley
                            MM252
                            MM211
                            Passport Plus w/Spool Gun
                            TA185
                            Miller 125c Plasma 120v
                            O/A set
                            SO 2020 Bender
                            You can call me Bacchus
                              Heavy Haul Trailer
                              This discussion makes me recall my high school days forty years ago growing up on a cotton farm.
                              We ran John Deere row crop tricycle tractors, mainly 70, 720 & 730's. The front wheel forks were subjected to a lot of abuse and tended to crack between the four 1/2" bolt holes where the fork was attached to the bottom of the steering sector shaft.
                              I think these forks were made with the T1 steel being discussed.
                              The repair that worked or took the longest to break again was to drill the crack ends, grind out the cracks and heat the bolt hole area as best we could with a multi tip rosette oxy-acetylene torch and weld with a "low hydrogen" rod. E-?????.
                              My question is what is / was this LH rod, what is its classification code and would it be useful for this type of repair of T1?
