MyAsianNotSoNormalHotRodThread
    For practice cutting... fitting.... tacking and welding exhaust tubing...
    you might go down to a local muffler shop and see if they will let you dig in their scrap bin for some drops and shorts..
    they are usually car guys and will probably let you scrounge..
    and yes mild steel will weld a little bit different than stainless.. but close enough to be quite useful...
    Besides if you foodl-dey-duck up some free mild steel... it will not hurt like if it was expensive stainless..
      Thanks
      You've been a great help but I'm still having the hf arc start problem. I fired it up yesterday and it would arc fire say 5 times then stop working. Then start working...an intermittent problem...frustrating.
      This machine with my back ground may have been a mistake purchase but it is what I have so I'm going to have to do some more trouble shooting.
        I need a brass ground clamp.
        With my machine should I get the 200 amp or the 300 amp?
        http://www.ebay.com/itm/300AMP-COPPE...item4d1df55382
          Originally posted by scratchedup View Post
          Thanks
          it may very well be a matter of getting used to the machine and settings as FusionKing had suggested..
          developing consistant technique takes time and practice ... touching the tung to the work and lifting it off before each arc start... making sure the tung is properly prepped and collets + conductor in torch body are clean.. without tarnish.. corrosion,, spark burn..
          also... had you checked and tightened cable connections as Cruizer had suggested??
          ANOTHER approach you might think about is to sell the Dynasty you have and invest in a new one...
          it really depends on if your budget will allow... and if you wish to bypass the learning curve/grief of arc starts on the older one... probably have no problem selling it
          or even find a newer "Blue Lightning" equipped one on the used market...
          (Dynasty 200 with a serial# of LJ280222L and above are equipped with "Blue Lightning")
          And you could go directly to working on the car...
            Either one should be fine... but that 300 amp Lenco is reasonable enough.. a little overkill here would not hurt anything..
            • #21
              Just got back.
              Bought a brass ground but had trouble finding lanthanated Tungsten.
              Went to 2 weld shops...no luck.
              • #22
                I'm about to put the Miller power cord back on and check the points so all connections will be checked.
                I like this idea...this may be to much machine for me anyway.
                I paid $1500 for the entire set-up with gas and a bunch of extra stuff. You have any idea of what it might fetch?
                • #23
                  Just got back.
                  This is the easy answer for 2% Lanthanated...
                  http://www.ebay.com/itm/10-HTP-2-Lan...#ht_841wt_1106
                  and your arc starts will probably improve as well...
                  there are several decent suppliers on fleabay/or internet..
                  • #24
                    Would think you could get $1500-2000 for the bare power supply.. but others might have a better handle on used prices...
                    would do some more checking..
                    for torch... reg..leads.. etc..do not know if you would buy all new or use the acces you have with the new supply..
                    might make sense to bite the bullet and go all new..
                    clean slate..
                    • #25
                      Yes thats what I figured....I use Amazon and Ebay all the time ...that was my next step.
                      GOOD NEWS.... I think I "fixed" the arc start problem.
                      New Brass Ground Clamp, Lightly sanded and MEK cleaned- grd to machine plug and torch cable plug to machine plug, all torch bits and reground & fine sanded tungsten (red...all I have for now) put all back together.
                      It fired about 25 arc starts....worked perfect.
                      Theres hope.
                      • #26
                        Theres hope.
                        Glad to hear that....... Thank Cruizer for that suggestion...
                        • #27
                          Compressor flange.....work in progress...welder's name is pirate...retired Delta airlines...
                          Cleaned up-
                          • #28
                            • #29
                              • #30
                                if you debur the inside of the tube and remove fins before it is fitted and welded... there will be a lot less that needs to be ground out after welding..
                                also it looks like he is cooking those welds... he might consider increasing the amperage and speeding up his pace...
                                it should result in smaller tighter beads that still have enough penetration to be sound..
