Miller Electric
Welding Discussion Forums
Home » Resources » Communities » Welding Discussion Forums
  • If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Announcement Module
blueprint reading
Page Title Module
Move Remove Collapse
Conversation Detail Module
    blueprint reading
    Well I assume your in the welding fabricating business so I would ask a coworker or get with the shop foreman and go over some old prints I work with pipe isometrics on a daily basis I learned by asking the more experianced guys I don't think any book would help on its own just get a blue book a square a plumb bob and a pencil and soapstone and read your ISP make a cut list and go from there
      Hey Luis,
      A blueprint is usually nothing more than a front view (elevation) a side view (profile) and a top view...(plan) Since it is sometimes read around the world from where it's drawn, a bunch of other info and measurements are used to guarantee they'll be understood and the measurements will be the same. There are traditions to how you do those measurements (this is what you learn in drafting classes...but you can see the conventions if you just look at a lot of blueprints...)
      Here's a link that helps understand how objects are divided up into blueprint views.
      http://en.wikipedia.org/wiki/Multivi...hic_projection
      You do learn HOW to draw them and divide them up if you take a drafting class,
      programs like Google Sketchup allow you to move around the views and see them in 3-d where as older guys like myself had to do the 3 views on drafting paper and imagine the object when it was done.... So it's a different learning curve and it's frankly a dying art. Someday soon there will be only 3-d forms that you can view in rendering programs...and you'll be able to print out the 3 views with no work at all.
      I read a great book on how to quickly see things in your mind from blueprint view called RAPID VIZ and it showed how to think quickly and visualize quickly.
      So you can start there.
      Another way to learn is to take an object that is pretty regular, like a box or something, and draw a front, side, and top view of the thing and match the measurements to a scale...like if the box is 8 inches high you use 1/2 scale and draw it 4 inches high on the paper.
      You can learn it and you'll find it's easy. Just a new skill
      Good luck
      Drewcifer
        I took a Welding & Blueprint reading course at my local adult education school. It was a 900 hour program with a day or two every week set aside just for blueprint reading. It was extremely helpful cause your working specifically with all the different welding symbols & lines & the different materials. In my mind unless its drafting for welders a drafting class is only a little helpful. If you dont know what the symbols mean your still pretty clueless.
          blueprint
          hint 1c1 is a column, 1b1 is a beam 1br1 is a brace, 1a1 is angle, 1t1 is tube, and so on
          Special Offers: See the latest Miller deals and promotions.
