utility trailer alignment
  • utility trailer alignment
    I have a 5' x 10' single axle utility trailer and am getting wear only on the outer edge of the tires. I have not yet measured camber or toe-in. Can someone tell me if a trailer of this size should have straight toe-in or not?
    You prob have camber where the axle is pre bent in the center but you should have no toe in unless the spindle is bent. Look under at the top of the axle and see if its humped a little...Bob
    Bob Wright
      Yes it was cambered. It had about 5/16" bow in the middle of the axle. I heated it up and tried bending it. got it perfectly straight on the first try. Thanks!
        I think its supposed to be bent/ cambered!!!
          Lol. Omg!
            perfect now you'll wear the inner edge of the tire
            MM 211 W/ Spoolgun
            Diversion 180
            Spectrum 375 X-TREME
            Portable Victor O/A
            Palmgren Bench Drill Press
            14" Evolution Dry Saw
            IR 60 Gal. 3 HP Compressor
            Speedglas 9100x
            My Brain
              You know this thread is over a year old....
              MillerMatic 251
              Maxstar 150 STH
              Cutmaster 42
              Victor Journeyman OA
