Fuel swirl/surge tank.
  • Fuel swirl/surge tank.
    Hi,
    I'm building fuel swirl pot. But i'm little bit confused about inner walls, baffle plates. Or aren't there any?
    This type tank
    http://www.merlinmotorsport.co.uk/p6...duct_info.html
    I was thinkgin something like this.
    http://i145.photobucket.com/albums/r...23/fuelpot.jpg
    Any ideas or suggestions?
    Rainer
    A. Graham Bell briefly discusses swirl pots in his book, Forced Induction Performance Tuning. He shows an illustration of a swirl pot without a baffle. I don't see a need for a baffle because the pressure pump is drawing from the bottom of the swirl pot. One difference between your design and Mr. Bell's is that he put the pressure pump fitting on the center of the bottom face of the swirl pot rather than on the side of the cylindrical surface. As a side note, A. Graham Bell says the tank usually should be large enough to hold 30 seconds worth of fuel.
    If my scanner was functional I would scan the drawing and post it. Sorry for that.
    Paul Lohr
    Syncrowave 350LX
    Dynaflux water cooler
    Weldcraft WP-18 torch
      Paul Lohr
      I have this book. But i saw that there weren't andy baffle plates. But i taught that they might improve fuel delivery during long lefthanders. ( car is bmw e30 with 3.2l MPower engine that need quality fuel delivery every second) I my case i had to put fittings on one side due to tank placement under the hood.
      Instead of 3 fittings like in the book, i used 4. 1) from feed pump 2) pressure pump to engine 3) fuel rail return 4) return to fuel tank
        If i could put prssure pump fitting at the bottom, then there wouldn't be much need for baffle plates.
          Swirl pot-- just a header tank by another name? If so, no need for baffles.
          The idea behind it is to supply it with fuel all the time, via a low pressure fuel pump (or gravity if your talkin' airplanes). If it's always full there's no need for baffles, as there should be no sloshing back and forth in a full header tank.
          Big Blue 400D
          Trailblazer 302
          Miller S-32 suitcase
          12VS suitcase
          Lincoln LN-7 (BIG suitcase)
          Victor torches
          Lincoln 350MP with 35' push-pull gun
          Lincoln PrecisionTIG 375
          Spectrum 1000 plasma cutter
            Swirlpot overview....
            Suvi
            found a pretty good swirlpot overview on a Subaru site
            http://forums.nasioc.com/forums/show....php?t=1458249
            hope this helps
            Regards
            Heiti
            My Blue Stuff:
            Dynasty 350DX Tigrunner
            Millermatic 200
              E30 engine swap....
              Suvi
              could you give us more details on the engine swap on that E30?? they are a good platform with a lot of available parts.. and right now they are available at very reasonable prices at least in the US... pics too please.. if you have..
              thanks
              Heiti
              My Blue Stuff:
              Millermatic 200
                This is the car
                http://opentrack.tqhq.ee/forum/viewt...tid=342&page=1
                  Suvi
                  am afraid that my Estonian is very very rusty...(since childhood) and the picture links did not work for me... my guess is that most here are even less familiar with the language.....could you maybe post some pictures on this forum for us???
                  Heiti
                  My Blue Stuff:
                  Millermatic 200
                    Here are a lot of pic's
                    http://www.ruus.eu/auto/m3/
                    And here are some of things i have done.
                    http://www.flickr.com/photos/rainersuvi
                      Labor of Love...
                      Suvi
                      that M3 must have been a labor of love!!! .... how many thousands of hours did you put into it? ..... really well done and a beautiful piece of work...
                      Looks like you had to make room, opening trans tunnel to fit the S54... pretty tight fit???
                      Also Flikr album pics.... the work that you showed would make any race shop here in the US proud....
                      Regards
                      Heiti
                      My Blue Stuff:
                      Millermatic 200
                        This M3 is not my project. I have just made some parts for it.
                          The pics of the car with the S54 conversion.... that was not the M3??? 2different cars? (just assumed it was the same car at different times in it's life)
                          The labor of love was about the white car that was totally disassembled with the enlarged trans tunnel....
                          Heiti
                          My Blue Stuff:
                          Millermatic 200
                            Yes this is the car. Only one car and it's M3 with S54 conversion. But i wanted to say that this is not my car and i am not the main builder. I just did some parts for it. It's truly amazing car. I always liked BMW's. Especially E30 and M series. Just raw performance and mechanics.
                            Rainer
                              Suvi
                              hope this helps
                              Regards
                              Heiti
                              very nice thanks for sharing
                              Private Investigators Delhi India | Gears Manufacturers
