Looking for cap and neck, for custom coolant reservoir
  • SunGuy
    started a topic Looking for cap and neck, for custom coolant reservoir
    I have no idea where to local one.
    I searched on summitracing and they have an EARL radiator neck (http://www.summitracing.com/parts/EAR-166015ERL/) but for that price, I might as well buy a coolant reservior at $45
    I would prefer a cap and a threaded neck so I can just weld the threaded neck to a tank I will built out of aluminum. Ideally, less then $15. Anyone know where to start.
    Thanks.
  • SunGuy
    Thanks for the suggestion. It seems like a cap and threaded neck is more expensive then I thought. At $37.00 for just a cap and neck, I can buy a universal coolant reservoir "Made of Billet 6061 Aluminum and then TIG Welded with Billet Aluminum CNC machined fittings and then Polished to a high quality shine" for $45.00. It will be hard for me to compete with that.
    Originally posted by PatrickW View Post
    they want $108 for a 3'' SS mandrel bend??
    I use ATP Turbo (www.atpturbo.com) for my mandrel bend pippings, turbo fittings and misc turbo stuff. It's only $44 for 3" SS U Bend.
  • DDM powersports
    I have always used pro-werks for components for tank projects. They are the cheapest around in my opinion.
  • PatrickW
  • FusionKing
    Originally posted by Mongo68 View Post
    www.Chassisshop.com
    They have a few sizes and even colors... Look under the body fabrication tab...
    I helped the link so it works www.chassisshop.com
  • Badd00SS
    Chassisshop.com
    Ditto, the chassis shop has really neat stuff.... I use them alot...
  • cupfab
    Another variation on Ronnie's reply....
    Use a threaded bung and a NPT pipe plug for the cap. You could weld a "wing nut style" handle on the pipe plug,or knurled knob for easy removal. Would look trick if done right, and the least expensive thing I can think of.
    You can get aluminum bungs on ebay.
  • Ronnie
    Get jic fitting in the size you want cut it in half (use a union) as that is all you require.
    Weld it to your tank and get a jic cap for it and you are done.
    Ronnie
  • aametalmaster
    Got a buddy with a lathe??? ...Bob
  • Mongo68
    Chassisshop.com
  • PatrickW
    Try Vibrant Performance,
    http://vibrantperformance.com/catalo...Path=1020_1232
    Ive ordered a few things from them and have always been impressed
  • engnerdan
    Moroso Weld on fill cap
    http://www.summitracing.com/parts/MOR-85282/
    If you are looking for a radiator cap style then I have no answer.
    -Dan
