Welding 1/2" 4140 bar
    Looks like you already got 'er done, cudo's!! For future reference tho:
    Preheat 5-600 degrees, if possible weld with a nickel/chromoly rod (such as Arctec's Unicrom series) and cool slowly. If you can't find that rod, ER80S-D2 is a real decent option for MIG wire. In the mean time, have fun!!
    WH
    Big Blue 400D
    Trailblazer 302
    Miller S-32 suitcase
    12VS suitcase
    Lincoln LN-7 (BIG suitcase)
    Victor torches
    Lincoln 350MP with 35' push-pull gun
    Lincoln PrecisionTIG 375
    Spectrum 1000 plasma cutter
      4140
      you can use duplex(2209) or super duplex(2507) with about 400f pre heat. It is very good for any sort of dissimilar welding
        A couple hundred passes later... looks great!
        Wags
        Oh, yes.. that is exactly how is is supposed to ride. The front sponsons are there for the ride after the launch. Bottom 1/2 of the prop in the water.
          Put some graphics on over the winter. Had to break up the red a little.
            Wags
            crazy.. you gota have a big pair to do that stuff! ill stick to 4 wheels
            • #21
              All in what you get used to I guess. It is not a beginner ski boat... that is for sure.
              Wags
              • #22
                Wags
                BTW... if you look at the back of the boat you see a black square behind the engine. That is the parachute. Look directly in line below that and you see a black piece with a shaft going forward. That is the strut.
                SO, you can see it carries the boat weight plus a ton of side load. (from bottom half of prop)
                Wags
