AEAD 200LE 60 hz GENNY/ WELDER
  • AEAD 200LE 60 hz GENNY/ WELDER
    Hi there..
    Okay, help... I have a broken wire marked number 34 from the negative terminal of the ignition coil, and the drawing shows that it goes to the Power Weld switch (S1). Should be easy eh... not on your life it is... I cannot see where this wire has come off from, nor is there a terminal that has lost a wire, despite the wire end having the remains of a terminal attached.
    SYMPTOM: For some reason, when the switch S1 is moved from the weld to power, the move kills the engine. Does this number 34 wire have a baring on this function? The diagram is not helpful in this respect and is rather poor to read. I think my glasses need glasses
    Help would be appreciated. email g6ypk@yahoo.com
    Kind regards
    Tony...
    Moderator> sorry I messed up the original message.. new, you see.
