breaking bolts loose?
    to break your bolts loose
    To break your bolts loose i would just get a socket and ratchet and tack weld a breaker bar to your ratchet to give yourself some leverage. You should do this when the engine is hot because what happens is the engine heats up and cools down which causes the bolts to get cold welded into the threads. Hope this was helpful
      Most good techniques have been mentioned assuming you can access the bolts. If there is anyway to spray a penetrating oil near these bolts, it will probably trickle down into the threads. MY FAVORITE IS PB BLASTER
      GOOD LUCK!
      HAWK
        I'll second the PB Blaster. Heat the bolts, tap with a hammer, and give them some PB. Let them cool and go to work.
        A 454 doesn't give you a lot of room, but if you have a 3/8 butterfly impact it will serve you well here. They wil rattle the rust loose without shearing off the bolts.
        Jeff
