weldcraft wp 17
  • squig
    started a topic weldcraft wp 17
    weldcraft wp 17
    Hey people i" ve been tigging along time and using wp17 flexes forever about a month ago i had one blow up like a bullfrog whenever i opened the gas valve i figured what the heck it doesn't owe me anything so on goes a new one and two days later i fired up a new one go to do some tacking and hear and feel a slight crack noise now this one starts too leak and blacken the welds whats up with this any ideas?
  • Bert
    post pics of it eh? of the old one AND the new one!
  • squig
    response
    Weldcraft and i have have talked and they suggested i switch to the red style as they will handle more heat ? i will keep yall posted
  • fabricator
    You can usually bend them a little and be okay.A flex head contains a coil to allow it to bend (there are new ones that use a different method).The fixed head torches use a copper tube that can be bent ,but over bending and too much will eventually get the best of it.
    You have 3 choices about your overheated tig torch.Use a 200 amp torch,a water cooled torch set-up or get another 150 amp torch and hose and swap them out when needed.
  • Ultrachop
    Wp-17
    Gents,
    I am new to the forum and a new owner of a Dynasty 200dx. (new to tig welding all together) I purchased the contractor kit with the weldcraft 150amp air cooled torch and was wondering if I can "purposely" change the angle of the head? Looks like it could flex right behind the backcap but after reading this thread I didn't want to break it?
    I have been practicing on some 1/8" aluminum and running upwards of 135 amps and for sure the torch gets pretty warm. I am considering getting a different torch, recomendations anyone?
    Thanks,
    Tim
  • Bert
    heard anything from Weldcraft about your torches yet? If not, take them to the next tent sale in your area and hopefully a Weldcraft rep will be there to give you new torches, or a better one
  • squig
    emailed them a week ago to see if it was somthing i was doing wrong because i have a ton of cups, lenses ect. havent heard a word o; well customer service is very important to me as i strive to maintain it for my customers
  • davedarragh
    Wp-17fh
    I was just thinking of getting one of these, but now I may just stick with "old faithful." Hmm, wonder if Weldcraft is aware of this?
  • squig
    switched over to a pro star and problem gone i still like the feel of the wp17 but buisness is buisness
  • fabricator
    I have had that happen also.I quit using that type.
  • squig
    sanitary welds mostly
    no hotter than 85 amps wondering if the glue?lets go after time?
  • FusionKing
    Totally weird...I wonder if your regulator is shot or something.
    How hot are you running it?? It's only a 150 amp torch.
    2 junkers in a row?
