How to build these type of tube mounts?
  • How to build these type of tube mounts?
    Is this just bar that has been bored out?
    It appears that thay have been drilled and spotfaced OR had a plug pressed inside of a short piece of tubing. Hard to tell as they are blurry and there is overspray on the face surface.
      Looks like a solid piece of round stock was drilled and turned. A piece of tubing was fishmouthed and then welded to the other piece.
        How many do you want????....Bob
          Well just 4 that would be nice but it be nicer if I can make myself too! But I can't drill out round stock like that big
            Why noy just use tubing??
              All you need is a metal lathe and some time...Bob
                well thats simple enough.
                seems like a tube with a plug center drilled would be the simplest / easy-est way if you don't have a lath. you could always drill the side of the tube to weld the plug in place threw the side. just get some tube and solid stock that fits tight, cut to fit.
                  had some fenders that had disconecting flaris that looked like that. it was a tube with a washer fit snug then tack welded on one side. used it so a bolt could join it then had plastic caps so you couldnt see
                    My guess is that it's a washer welded inside the tubing. The reason being to prevent the bushings from distorting too much under load (which would change the drive line geometry).
                    This is part of a high travel type off road suspension kit right?
