Antique floor jack
    Originally posted by Steve View Post
    And if you read the dirctions correctly you would never depend on the floor jack to hold anyting up while you crawled under and would use it to jack only, support with floor stands for the weight. To many people have been killed depending on hydraulics. Use proper blocking and not just the jack.
    That is an excellent point, the stuff I mentioned about the cheaper jack bleeding off and the expensive one not bleeding off is what the salesman at Napa told me.
    My sincere thanks , Pete.
    Pureox OA
    Westinghouse 300 amp AC stick
    Miller Syncrowave 250
    Hexacon 250 watt solder iron
      Word of warning:
      If you lift up a load and hear your jack 'popping' or 'clicking' but not dropping the load, it has a holding ball problem and should be rebuilt. The check ba!!s (nice censoring) are metal on metal and when a ball leaks it hammers the seat and produces a 'pop' or 'click' that you'll hear clearly. You might not be able to see it drop, but it is... VERY slowly. No leak to the outside, just a leak inside that will only get worse as the seat gets hammered. You can still use the jack, just DON'T TRUST IT! (Doesn't make much sense, but there it is).
      Oh, also this:
      If it your jack ever does start bleeding down, tightening the release handle harder seldom fixes the problem. That's a holding ball issue as well. All you are doing is jamming the release needle into its seat and ruining that! It's a whole separate hydraulic circuit back to the tank, not the part where the problem is. Couldn't count the number of times I've seen this. You can ruin it and make it non-rebuildable by damaging that seat!
        Your right cheap jacks stink, but then most cheap tools stink anyway. I never buy cheap jacks as they are used in a fleet shop. Best ones we have are old walkers, gray makes nice stuff too but pricey, OTC seems OK, the worst I've had was Lincoln 10 ton. leaked brand new and I bought 5 of them. All leaked, sent em back came back still leaked, and we always use jack stands, but its bad when it wont stay up long enough to get the stand under the trailer.... Sent em back and bought snap-on, looks just liek the lincoln but have had no problems, who knows. Use the big ones mostly on trailers since we have lifts that will pickup all the trucks even the 10 wheelers.
        ps: looked around shop and counted 12 floor jacks of various sizes...
        since I was counting I counted , 10 lifts, [3] 36,000lbs, [5] 54,000lbs, and[2]10,000lb lifts. Who needs a floor jack anyway...ha ha
        Scott
        HMW [Heavy Metal welding]
          Snap-Ons are Lincolns. They make bigger frames and bump the overloads up to rate at 2-1/2 tons. Same power unit as the 2-ton. Too spendy for me!
          I've rebuilt many many 10 ton Lincolns. They rock, you musta got into a bad production run...??? OTC is a VERY good brand hydraulic rams and pumps (bead breakers too) but their jack line was acquired in a company purchase.
          Thank god nobody has mentioned that import crap! BUY AMERICAN!!!
            Funny you say that cause they sure did look like them, but no issues
            Scott
            • #21
              pb412
              I enjoyed the talk about antique jacks. Due to health I'm trying to sell an old Manley 2 1/2 ton floor jack.I have no idea where to sell it that it can continue to perform !!! I hope I can post this Info here as well as this contact info ! pb... mybrownsound@atlanticbb.net
              • #22
                Thats awesome, I wish I had the room...
                Ironically I have an old Manley 3 ton Wrecking boom that I found in the dump, I restored it and use it to pick up steel beams, they made a very good product...
                Voigt Precision Welding, Inc.
                Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
                2007 Silverado 2500HD (tow vehicle)
                2000 Camaro SS (Race car)
                • #23
                  Where are you located? I will be at the vintage grand prix this weekend and someone there may be interested in your jack.
                  Pureox OA
                  • #24
                    Sorry to get back to post a reply. I live in Cumberland Maryland. I hope somebody can put this Bear to work I'm sure it could tell some stories. It might be larger than 2.5 tons, It is about 54" long not including the handle. I'll do some more checking tonight and measure the cylander. Thanks for your interest and help ! pb...
